1pastnew
Jan 25, 2022Follower
nighthawk mesh MR 62 wifi security no longer private
HI I DISCONNECTED MY WIFIF SYSYEM TO MOVE IT UPON RESTARTING I GOTY A AMESSAGE THAT SAYS THIS LOATION IS NOT PRIVATE. ...FOR EVERY SEARCH I DO. LIGHTS ON THE TRANSMITTER AND SATTELITE ARE BLUE.
I RESET BOTH HOME AND SAT ROUTERS
NO IDEA WHAT TO DO
PLS ADVISE IF YOU HAVE AN IDEA
1 Reply
did you move the modem/gateway as well?
What modem/gateway is it connected to?
Did you try factory resetting and reinstalling it?
