akballer
Mar 18, 2021Aspirant
Nighthawk Mesh WiFi 6 Router MR60 - Freezing during video calls
I have this mesh system and use it to run my home network. For the first 3 weeks, it was running flawlessly. Then we started to get freezing issues during video calls. A few days later, Netgear relea...
Christian_R
Mar 23, 2021NETGEAR Employee Retired
Hello akballer,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
akballer
Mar 25, 2021Aspirant
Apparently you missed the part where I've called your "support" team 20 times. Netgear tech support is about worthless.
