Robert8685
Apr 03, 2020Guide
NightHawk MR 1100
The NightHawk MR1100 is supposed to be unlocked, purchased from Best Buy but with no SIM, purchased SIM from OTRMobile which uses AT&T network, but when i tried to change the SIM from AT&T to T-Mobile it would not connect the display indicated it was locked.
How does one unlock in order to use another SIM card?
Thanks
1 Reply
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
