mbrandon32
May 03, 2021Aspirant
Nighthawk MR60 - Satellite Won't Sync
Nighthawk MR60 satellite was connected for a couple weeks. All of a sudden, it was showing an amber light. So I disconnected and moved it closer to the router in order to re-sync. After multiple rebo...
Christian_R
May 06, 2021NETGEAR Employee Retired
Hello mbrandon32,
May you hold down the reset button for 15+ seconds using a pin/needle to factory reset the system.
Christian
- mbrandon32May 07, 2021Aspirant
I ended up resetting both the router and satellite and starting over from scratch with both. Thank you for your reply.
- Christian_RMay 10, 2021NETGEAR Employee Retired
Hello mbrandon32,
Thanks for providing an update to your post.
Christian
