szuppo
Apr 22, 2020Tutor
Nighthawk MR60
Do they sell additional satellites for this system? I can not find a stand-alone satellite to add to my mesh. The system only comes with the Wi-Fi Router and one satellite but I’d like another due to ...
Christian_R
Apr 23, 2020NETGEAR Employee Retired
Hello szuppo,
We recently have sold MR60 satellites separately to add-on. We are currently out of stock but should be available soon.
https://www.netgear.com/home/products/networking/nighthawk-mesh/ms60.aspx
Christian
miwitte
May 31, 2020Aspirant
So I have a MK62 that works fine and I purchased a MK63 intending to connect the two MS60's to the existing MR60 and MS60 from the MK62 kit. Are the satellites that come with the kit hard coded to their router? They won't pair and I assumed the MS 60s from the kit are the same as the standalone. Is there a workaround or do I return and wait for the MS60 add one?
- Christian_RJun 04, 2020NETGEAR Employee Retired
Hello miwitte,
The additional satellites purchased purchased with the MK63 kit should pair with your existing MR60 and MS60. May you try factory resetting all units and running through the setup assistant again connecting all 3 satellites at the same time.
Thanks,Christian
