adampbowley
Mar 24, 2021Aspirant
Nighthawk MS60 Satellite intermittent connection (Blue/Red light)
I'm running 2 satellites - 1 in the house and 1 in my garden lodge. When I installed this system, it connected well and all was good. At some point this stoppped being the case, and despite movin...
adampbowley
1 other point is that the Network Map changes alot. 1 minute it's connected to the router, the next to the other satellite...
- Christian_RMar 25, 2021NETGEAR Employee Retired
Hello adampbowley,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- adampbowleyMar 26, 2021Aspirant
Unfortunately, I bought this in September. As I said it seemed to work for a while, but now can't get a consistent connection.
Just want to know if it's the distance or how if I can get it to connect 1 minute, is there a way to make it stay connected.
- Larry101Mar 26, 2021Star
See my similar problem from another topic's post:
So far they works OK without disconnecting from the router, if I connect both Satellites to the routers.
