2911Productions's avatar
Nov 14, 2022
Nighthawk Nightmare - won't factory re-set (tried the 7 second and 30 second button-press...)
Nighthawk Nightmare - won't factory reset
(have repeatedly tried the 7-second and 30-second button press with the paperclip...)
I have the Nighthawk RAX 50 (AX 5400 6-stream router) AX5400 WiFi Router (RAX50)
I tried to do the firmware update and now it's bricked. Can't access routerlogin.net, it isn't broadcasting any sort of discernable WiFi SSID (its default should be NETGEAR23).
I have downloaded the latest firmware  V1.0.12.120 to a thumb drive.
Is there a button combo to load/update firmware manually using the USB on the back?
I'm afraid it's toast - and not sure what to do next.
Any suggestions?
1 Reply
