Tempoment
Aug 16, 2019Aspirant
NIGHTHAWK OR ORBI MESH
If you have a smart home with a lot of wifi connected devices (smart speakers, lights, TVs, gaming consoles and pc), would you get a Nighthawk router (ax8 or 12) or an Orbi mesh system? Thanks
Tempoment
The house is approximately 280sqm so range is not really an issue, more so connected devices
- michaelkenwardAug 17, 2019Guru - Experienced User
Not really something that is open to a this/that answer.
Some like one option, others prefer the other.
Feed your requirements into the product pages.
Wifi Router | Wireless Routers for Home | NETGEAR
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
- avtellaAug 17, 2019ProdigyIf you don’t have a range issue/dead spots then a router is probably better than a mesh platform as it allows for much high throughput.
