XCurler
Dec 10, 2022Follower
Nighthawk Power Supply
Does anyone know the pin and barrel dimensions of 19 VDC Power Supply for RAX Nighthawk Router?
Dec 10, 2022Guru - Experienced User
There are many different RAX routers and power supplies. Usually putting in the RAX### model # will find you the right power supply from places like Amazon or ebay. I get mine mostly from Amazon.
