mmcap
May 25, 2024Tutor
Nighthawk R6700AX - How to set static IP on VirtualBox VM
Hi all, My Nighthawk R6700AX router refuses to grant access to my virtual machine. It is a Linux guest machine running on a Windows 11 host machine. I have configured the the guest machine with a br...
mmcap
May 30, 2024Tutor
Thank you for the advice. I reserved my desired IP in the router to keep DHCP from assigning it to another host. Then I set that IP as a static IP in the VM. The VM connects to the internet and I am able to ping the VM from my host machine now. Problem solved.
Thanks again.
Norm
