lfholmer
Dec 10, 2021Follower
Nighthawk R7000P Internet Interruptions
Guys, I have a Nighthawk R7000P router that is approximately 3 years old. The firmware is V1.3.1.64 and the ISP last year converted to fiber optics with the associated modem and UPS system. When I r...
Dec 10, 2021Guru - Experienced User
Unless you've setup a lot of custom address reservations, a reset doesn't take much time. So long as you're using the same ssid/password, devices should just auto-reconnect.
What modem/gateway is the router connected to?
Do you have IPv6 enabled?
