ricktgray
Sep 23, 2020Aspirant
Nighthawk RAS35 not resetting
I changed ISPs and needed to reset the Nighthawk. Pressing the reset button for seven seconds looks like it power cycles and resets it but doesn't. Constant red blinking power light, rare flashing am...
Christian_R
Sep 29, 2020NETGEAR Employee Retired
Hello ricktgray,
Were you able to sort this out? I would recommend opening a ticket with support and request for a hardware check.
Christian
ricktgray
Oct 01, 2020Aspirant
I have found no solution and thave opened a ticket but then realized I would have to buy extra support for about half what the router costs to receive an answer so I have basically dropped this issue.
- Christian_ROct 02, 2020NETGEAR Employee Retired
ricktgray,
I can see if support can follow up on the ticket you opened up. If you wish to be contacted, please send me a private message with your email address and case number.
Christian
