Hankj
Jan 30, 2021Aspirant
Nighthawk RAX 120 inconsistent operation
Hello
My Nighthawk Router AX12 RAX120 has been a bit of a disappointment, very expensive, inconsistent performance. Should I replace it with a new router, perhaps a mesh for my 2 story, 3500 sq ft house?
if so which model would be best for a 1 Gbps service and 30+ connected devices?
thanks,
Hank
- valentinulAspirant
For a house or an apartment with a large footprint, I would go with a mesh solution.
- pkgaddLuminary
3500 sqft over two storeys is quite a lot to serve by a single wireless router/ AP, so multiple APs or a mesh solution (e.g. the orbi RBK85x would come to mind) should improve the situation - especially at higher speeds over the 5 GHz band (which is more attentuated by walls/ ceilings than the slower 2.4 GHz band).
That out of the way, it's very difficult to provide guidance if you don't specify what problems you notice with the RAX120 (which is a good router) or what you consider to be not fast enough (over what range, obstacles in the way and how fast your client can be). Yes, IEEE802.11ax can give you >1 GBit/s throughput over shorter ranges and with a capable multi-chain client, but distance (walls) and lower-end clients can't unleash its full potential or do wonders,
