dzachau
Jan 25, 2020Tutor
NightHawk RAX 200 and VPN
I am currently running ProtonVPN on my desktop computer in my home. I would like to install ProtonVPN on my RAX 200 Nighthawk router so that all the devices in my home are protected by the VPN. When I go to the VPN set up it does not let me enter my ProtonVPN credentials. Is it possible to use ProtonVPN set up in the RAX 200? If so, is there an install guide I can be directed to? Thanks very much!!
> [...] I would like to install ProtonVPN on my RAX 200 Nighthawk router
> [...]To me, that sounds like a good question for the ProtonVPN vendor. I
know nothing, but my quick Web search found:https://protonvpn.com/support/categories/download-and-setup/
There, I see:
How to setup ProtonVPN on DD-WRT routers
Are you running DD-WRT on your RAX200?
- dzachauTutor
Thanks for the reply! Unfortunately I have learned the NightHawk RAX200 does not support DD-WRT. Here is one opinion I found......
I could not locate DD-wrt / Tomato /open WRT ready made image. Netgear have released GPL source code https://www.downloads.netgear.com/files/GPL/RAX200-V1.0.1.12_gpl.zip (900MB file). which you can build openwrt from.
From what I have experienced with top of the range expensive routers do not seem to get support from the Opensource developers, the response has been,not enough demand and too time consuming etc. I have ended up paying a developer in India to help me with my R9000.
- avtellaProdigyNetgear does not support any third party VPNs other than Pure VPN. PureVPN is kinda bad (slow/inconsistent) and their no logging claim is a bit shady.
If you want third party VPN support either complain to them or vote for my suggestion in the suggestions forum to allow third party Open VPN profiles from other companies like ExpressVPN, NordVPN, ProtonVPN etc...
