sgod
Aug 11, 2019Aspirant
Nighthawk RAX 80 Not Connecting to the Internet
I just purchased the Nighthawk RAX 80 and went through the set up process, but my router is not connecting to the internet. I checked to see if there is any issue with internet because of my modem (A...
michaelkenward
Aug 12, 2019Guru - Experienced User
Did your troubleshooting include the essential boot order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
Get that wrong and your router may not connect to the Internet.
- sgodAug 12, 2019Aspirant
Thanks for the help, but I followed your instructions and still it do not work. I was able to confirm today at work on a different network that the Internet port on the router is working. When I arrived home, however, to connect to the internet, the same problem occurred. I am not sure what is creating the problem at home. I again connected the ethernet cord into my computer and I have internet access.
- michaelkenwardAug 13, 2019Guru - Experienced User
There really isn't much to go on here, so you will need as real expert to chime in.
I can only think that the modem needs some sort of configuration to allow you to plug it into a router. But if you have simply replaced one router with another it is hard to see what you can change. And the only manual I can find for this modem is from 2011. So might not be the right one. It doesn't even go into connecting a router.
Can you actually get into the router browser graphical user interface (GUI) without an Internet connection?
You should be able to do this without any connection between modem and router.
Just plug your PC into an Ethernet (not Internet) port on the router and aim the browser at it. As in the Connect to the Network bit in the manual.
>>> RAX80 | Product | Support | NETGEAR<<<
You can then check the firmware and even update it manually.
Life should not be this difficult. Sadly, the RAX range seems to be "work in progress".
- sgodAug 13, 2019Aspirant
Thanks for your help. I switched out my modem and now my internet is working while connected to the router. My speed with the RAX80 is great. I am not really not sure why the switch in modem is working, when the modem was previously working and connecting to the internet with the ethernet cord, but I am glad that it is working.
