sparhawk2020
Sep 25, 2020Tutor
Nighthawk RAX series
I'm interested in the Nighthawk series, specifically the AX12, 12-Stream AX6000 (RAX 120) or AX8, 8-Stream AX 6000 (RAX 80). I note that both have "simultaneous dual band 2.4 and 5GHz" capability...
Sep 25, 2020Guru - Experienced User
this article has the "applies to devices" on the side.
sparhawk2020
Sep 26, 2020Tutor
Plemans, THANK YOU, for your quick reply and help!
I think that gives me all the info I need. I've decided to go with the Rax120 and am looking forward to buying / using it.
Again, your assistance is truly appreciated.
