bionanoscience
Mar 09, 2020Tutor
Nighthawk RAX120 - Fast Wireless Download Speed, Slow Wired
My ISP is Comcast/Xfinity with a 1-Gig subscription. When I hardwire my desktop directly to the Arris SB8200 modem, my download speed is approx. 940 Mbps. When I wire the desktop to the router and wi...
Mar 10, 2020Guru - Experienced User
When you push the reset button, make sure the router is powered on and to push for 7-15 seconds. The lights should change when held long enough.
Make sure to disable any traffic monitoring, circle, qos, or anything like that.
Have you tried speedtesting a different hardwired device into the router?
Are you using link aggregation? I know the SB8200 supports it and so doe sthe RAX but its had issues from both arris and netgear.
here's where you can get the manual
https://www.netgear.com/support/product/rax120
Topology
Mar 10, 2020Virtuoso
Bionanoscience, two comments for consideration…
[1] You can perform a factory reset of the router through the browser interface – see ADVANCED | Administration | Backup Settings | Revert to factory default settings | Erase
[2] Installing “Firmware Version 1.0.1.118 - Hot Fix” must be done manually, in my experience. Download “RAX120-V1.0.1.118_BETA.zip” from here, extract the “RAX120-V1.0.1.118.img” file to your desktop, and then upload it to your router through the browser interface – see ADVANCED | Administration | Firmware Update | Locate and select the upgrade file on your hard disk
