bigendian
May 26, 2021Aspirant
Nighthawk RAX120 AX12 5GHz band keeps freezing
Hi there! I just begun using my Nighthawk RAX120 AX12 and it has been a strange experience so far unfortunately. Connecting my Mac or iPad to the 5Ghz band, that band simply seems to freeze up and ...
May 26, 2021Guru - Experienced User
after the firmware changes, did you ever try a factory reset?
Did you try other devices other than apple?
- bigendianJun 10, 2021Aspirant
Yes, unfortunately I've tried everything!
I tried factory resets, downgrading, upgrading. It is not specific to Apple, it begun happening on my Window devices too, seems to be a router issue that others are having too. This is most expensive horrible router I've bought in my life.
The only thing that seems to have worked for now is turning off the AX band, which sort of defeats the purpose of getting a WiFi 6 router.
Thanks!
