MadHatter0101
Apr 09, 2019Tutor
Nighthawk RAX120 Beta Feedback
Let me start by saying I also have the Asus GT-AX11000 router and 2 s10's that I have 802.11ax for testing. I am a Systems Administrator and setup\design networks for a living.
First the hardwa...
MadHatter0101
Apr 09, 2019Tutor
I dont remember if DumaOS has a per device break down. I had an XR500 for a while, but moved back to Asus about a year ago. I hate sounding hard on Netgear, but their routers are a mess when it comes to features. It just seems like the RAX120 could do so much more, its just the OS is holding it back. I was told Netgear Armory will not be coming to it from Netgear. Disney's Circle will be added at some point, but it could be 6-12 months. Hardware is solid, I just dont know why there are zero gaming features and its running a gui from 2001.
I moved to the Asus Rog Rapture GT-AC5300 and didnt look back at the XR500. Then in Dec. I got the Asus Rog Rapture GT-AX11000. I only had one issue with it and it was fixed in the last update. Asus is not perfect, but they at least under stand that a $500 router needs to have a OS\GUI with lots of features. Anytime you have a router over $300 you are aming it towards Techs or Gamers. Shipping a router that cost $500 with a stripped down OS\Gui will not go well.
schumaku
Apr 09, 2019Guru - Experienced User
Do the Asus Rog properly show _all_ attached devices, regardless if wireless, connected direct to the LAN ports, or connected to the LAN ports through switches, wireless extenders, wireless bridges, ... ? DumaOS seems to have massive limitations on that part, making it not feasible for the tech geek who typically has much more devices on the network than LAN ports are available, has switches, power line, extenders and repeaters deployed.. What might be OK for the high end gamer isn't good enough for us techies.
- MadHatter0101Apr 09, 2019Tutor
The Asus shows a complete breakdown. Its sorts by connection type. So it shows Wired \ 2.4Ghz \ 5Ghz-1 \5Ghz-2 (It has 2 5Ghz radio's). I took a screenshot, it only shows you part of what I see, but you will get the point. I have 2 unifi managed switches with a Cloud Key and it all plays fine with Asus. DumaOS does not have all the feature that Asus has, but DumaOS is a million times better then the junk thats on it. Netgear has to start somewhere.
DumaOs is a seperate company out of the UK. Netgear needs to buy them. Then look at adding more features. DumaOs is a solid foundation. DumaOs is more for gamers then Techies, you are right on that. DumaOS is modular if I remember right so you can add to it very easily.
- schumakuApr 09, 2019Guru - Experienced User
Absolutley, agree MadHatter0101 ... have placed some proposals for installable modules to the NetDuma reps already btw.
I would love to see DumaOS have built in Bitdefender for both Antivirus and Parental Controls. Netgear needs to split Bitdefender in to two products. The first is router only with the two above features. This needs to be included for free or lets say $5-$10 per year for def updates. Then have the option for $70 that they already have so you can put it on your pc's and phones.
Now long term what would be fun with DumaOS is a feature I saw an Android router that never came out have. That is a Store built into the OS. So for example you could pick the AV, so if you didnt like BitDefender you could choose Norton, etc. I have to say though Bitdefender makes the best AV, I use them at home and work. Back to the store you could do VPN, firewall Gaming services, etc. Some will come free and some will be paid. So you could customize the router's OS to your needs.
