MadHatter0101
Apr 09, 2019Tutor
Nighthawk RAX120 Beta Feedback
Let me start by saying I also have the Asus GT-AX11000 router and 2 s10's that I have 802.11ax for testing. I am a Systems Administrator and setup\design networks for a living.
First the hardwa...
schumaku
Apr 09, 2019Guru - Experienced User
Convinced we will see Wi-Fi 6 Netgear routers with DumaOS in the not so far future as dedicated models, one day we might see Netgear Armor (Bitdefender) on the RAX series, for backward compatibility the USB sharing type ReadyShare Print, one day even a Hybrid VPN with true policy routing, ... and of course correctly working Network Maps (with names, and device types tat stic and are the same in the Web UI, IP address for IPv4 / postfix reservation for IPv6, DHCP6, local DNS for the [W]LAN, ...) in the Nighthawk App - not like the mess we see on the Nighthawk series and Genie App - would be nice (currently it does not even exist - except of a CES2019 promotion video).
Aside, does Duma OS have a per-client data counter, and an ability to enforce per device quotas?
Ways to go, Netgear!
carlosriosness
May 08, 2019Tutor
i just asked for the same feature.
i am coming from the google mesh system. it lets you select "current data usage" and you can see all currently connected devices and their bit rate. you can select "data usage today", "data usage this week", or "data usage this month" and it will show you all devices connected in that range and their total MB's used for that range.
i have the same issue where i live with roomates and our 4k streaming puts us at or over the cap and i like to know how,when,where our data is being used.
i too love the routers hardware. but the google mesh app is much more intuitive and gives much better data. the only thing it can do is set a data cap to cut off data usage at XXXXGbs per month
