Redtulips7
Jun 11, 2019Luminary
Nighthawk RAX120 Firmware Version 1.0.1.86
RAX120 Firmware Version 1.0.1.86 Bug Fixes: Throughput issues occurred with Samsung Galaxy S10 (with WiFi 6) devices. The web interface incorrectly showed the register/unregister information afte...
Redtulips7
Amazon Fire TV[NOT STICK] not seeing 5ghz SSID when DFS Channel engaged!!!
Router range are greatly reduced from AC Router[Tried all FW]
No WiFi dropping so far
Still 1971 UI
schumaku
Jun 11, 2019Guru - Experienced User
Redtulips7 wrote:Amazon Fire TV[NOT STICK] not seeing 5ghz SSID when DFS Channel engaged!!!
Assuming you are located in the US, so FCC is applicable: As per the FCC S59-4891 applicable to the Amazon Fire TV (CL1130):
The range 5180.0...5240.0 MHz (Ch. 36..48) and 5745.0...5825.0 MHz (CH. 149...161) do indeed cover ZERO DFS channels - I fear you dig at the wrong construction zone.
FMI: https://www.amazonforum.com/forums/devices/fire-tv/466853-fire-stick-cant-find-5g-wifi an Amazon staff meber wrote (back in 2017 - so this might have changed for some models since....): "At this time, Fire TV and other Fire TV devices do not support 5Ghz DFS (Dynamic Frequency Selection) Wi-Fi bands. ..."
As per the above, lack of a FCC permissive change for the Amazon Fire TV box, ... no change.
- Redtulips7Jun 11, 2019Luminary
Yes I am in USA, probably newer upcoming Model will support then????
