JustBob
Nov 22, 2022Aspirant
Nighthawk RAX120 WiFi radio(s) not starting
So, I leave town and after one day my WiFi cameras at home go offline (not connected to WiFi). Upon return, I find the AX6000 Router has a steady power LED on, and a flashing Internet LED on, and no other LEDs lit. After multiple power-offs and checking all connections, the router will only display the same as above. I also noticed that it appears the cooling fan is not turning.
So, is it a dead unit? No other electronics are harmed, and the cable WiFi is working just fine.
Thanks for any feedback!
My better-half just found the solution...hold down the "WiFi On/Off" button for a good count of 10. The radios all came back on! Amazing...
- JustBobAspirant
A couple of seconds works here.
Many people don't realise that those LEDs are also switches.
Heaven only knows how it got switched off in the first place. (Cats and infants are the usual suspects.)
