adrirodr
Nov 07, 2020Aspirant
Nighthawk RAX120
Hello folks, I have a Nighthawk RAX120, worked flawlessly until a couple weeks ago. It will work without issue, then it "hangs" WiFi connectivity drops, unable to join the network, even wired tra...
Newfiedrool
Nov 07, 2020Virtuoso
What firmware are you on?
adrirodr
Apologies I can’t recall, it has been replaced with a RAX70, but it was current, updated to the most recent firmware. I’ll try firing it up later and connect directly to it to get the actual FW version.
- NewfiedroolNov 07, 2020Virtuoso
No worries. Make sure it's up to date then perform a factory reset using the rear pin hole method.
set the router up as new, don't use a saved profile config and test. It could be it just needs a reset to clear the NVram of old code.
