adrirodr
Nov 07, 2020Aspirant
Nighthawk RAX120
Hello folks, I have a Nighthawk RAX120, worked flawlessly until a couple weeks ago. It will work without issue, then it "hangs" WiFi connectivity drops, unable to join the network, even wired tra...
inspectorgadjet
Nov 23, 2020Apprentice
Are you using Armor by any chance? My RAX120 has been driving me crazy with the newest firmware. Constantly dropping connections and freezing. Tried all the usual, factory reset, install the firmware from the downloaded file instead of OTA, etc. but nothing helped. Turns out Armor was causing it. I disabled Armor last week and the router hasn't had any problems since.
