tjschramke
Feb 28, 2024Aspirant
Nighthawk RAX120V2 DROPPING SPEEDS TO 100
Nighthawk RAX120V2 DROPPING SPEEDS TO 100 - Any solutions to this... I have rebooted multiple times - changed out cables... please help. Thank you
Feb 28, 2024Guru - Experienced User
Happening over wireless and wired?
What devices are connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How is the RAX120 configured and connected to the ISP service device? Yellow WAN port or the Multi Gig port?
tjschramke
Happening over wireless and wired? BOTH
What devices are connected? wifi devices are cameras, laptops 2x, desktop, Frig, 2 gaming consoles, phones...
What Firmware version is currently loaded? The current version V1.2.9.52
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? using only netgear and plugged into the wall...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. I will have to check - how?
How is the RAX120 configured and connected to the ISP service device? Yellow WAN port or the Multi Gig port? Yellow Wan port. and then 2 other ethernet going up stairs for wired connections.
- tjschramkeFeb 28, 2024Aspirant
The wired is PlayStation and desktop computer and tv
- FURRYe38Feb 28, 2024Guru - Experienced User
So your ISP service is just a wall out let that they told you to connect the router too? No physical box device anywhere?
Does the top Internet globe LED turn AMBER when this happens?
There is printing on the cables that indicate CAT#.
Yes and amber on 2 lan ports all the time but no it does not turn amber. I have not done a factory reset - I have to work with internet service and they are local - we work from home so that is why I have not yet.
- plemansFeb 28, 2024Guru - Experienced User
You can log in and check what each port is connected at.
How do I display Internet port statistics on my Nighthawk router? - NETGEAR Support
