Am1992
Jul 31, 2023Aspirant
Nighthawk RAX120v2 firmware: v1.2.8.40 drops at least once a day
I just recently purchased this router a month ago after our very old Nighthawk router died. Since installing, the Wi-Fi connection drops at least once a day, sometimes multiple times. Lights go out...
Am1992
Aug 07, 2023Aspirant
I’ve installed the firmware beta, factory reset and set up from scratch, plugged unit directly into a wall outlet instead of a power strip, etc.
Still getting daily reboots.
For a device that costs over $200, it sure does suck. I mean, I should’ve even have to jump through hoops to get this thing to actually run properly.
That firmware beta has been “beta” since October 2022. Exactly when does Netgear feel it’s appropriate to actually try and fix this problem?
I’ve been buying Netgear products for over 15 years but this is about to make me throw it all away and get a different router from a different company.
- FURRYe38Aug 08, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.You sure you installed the beta FW correctly and then factory reset the router and setup from scratch?
What channel configurations are currently set on the router? Basic and Advanced...
What other devices are connected to the router? Wired and Wireless?
What are you doing and using thru the router when the reboot happens?
Armor, Smart Parental Controls or Circle, Traffic Meter.
