cordycep
Nov 17, 2021Follower
Nighthawk RAX15 -LAN setup change subnet mask but it does not get change
Under Netgear LAN menu setup, I change the subnet mask from 255.255.255.0 to 255.0.0.0 and click apply. But checking network setting using "ipconfig/all" the subnet mask never got chang...
Nov 17, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
