meatymeatballs
Sep 19, 2022Tutor
Nighthawk RAX20 - Connected devices stopped communicating (not guest network)
Nighthawk RAX20 Firmware Version V1.0.11.112_2.0.77 About a month ago I noticed the devices on my home network had stopped communicating with each other, for example; I could not cast YT or Netf...
Sep 20, 2022Guru - Experienced User
What modem/gateway is the router connected to?
meatymeatballs
Sep 20, 2022Tutor
Hi plemans, my gateway is NBN CPE - I'm in Australia, so on the NBN with fibre to the premise. Hope that is what you mean?
- plemansSep 21, 2022Guru - Experienced User
nbn cpe literally means: national broadband network customer premise equipment
The equipment should have a label on it with a model number. That'll help more.
- meatymeatballsSep 22, 2022Tutor
Understood - the model on my NBN box in the garage says G-240G-P. Apart from that it just has serial numbers and MAC.
My router plugs directly into the NBN box and I should point out I've been in this house 2 years and all the devices have been connected with no issue. I got the RAX20 AX1800 wifi router about 9 months ago and it hadn't had any issues until recently
Thanks
- michaelkenwardSep 22, 2022Guru - Experienced User
Sounds like a true fibre box, an Optical Network Terminator (ONT) with nothing routerish to get in the way. In theory, that is the best sort of Internet you can get.
You mentioned "a Google home device". Anything in particular? Google has made a lot of things that could fit that description. Could that be getting the way?
If your theory about "crosstalk" between guest and normal wifi settings is correct, then trying the older firmware could confirm that.
- michaelkenwardSep 21, 2022Guru - Experienced User
... my gateway is NBN CPE - I'm in Australia, so on the NBN with fibre to the premise.
NBN just means Ozzie internet.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
With FTTP there may not be anything more than an Ethernet port between the Internet and the router. But you never know, such is the variety of NBN services.
