Radeczek
Oct 24, 2022Follower
Nighthawk RAX20 - Is it comaptible with WD BLACK P10 GAME DRIVE 5 TB?
Oct 24, 2022Guru - Experienced User
Sadly, its more along the lines of you have to try it. Its hit/miss with a lot of these hard drives and depends a lot on partitioning and format of the drive.
michaelkenward
Very true, but this is a good a place as any to start:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Radeczek may not find the exact model, but something near enough should be a good guide.
That list is not up to date or complete. For example, I can use a couple of drives that do not appear in the list for my R7800, including an 8TB Seagate Backup Plus and a 4 TB WD Elements.
But the format advice is crucial. ReadySHARE hates partitions.
