Srl2007
Jul 28, 2020Aspirant
Nighthawk RAX200 as APs across home
Brand new home built with Cat8 wiring to every level. Can I put RAX200's on each floor and set them as APs and connect them with a netgear switch to create a wired mesh with the same SSID to cover t...
Jul 28, 2020Guru - Experienced User
The only problem is its not a mesh system. You can use the same ssid but it won't roam like a mesh system would.
You'd be better to look at the orbi AX system versus multiple RAX200's.
- Srl2007Jul 28, 2020Aspirant
1 - thank you for the info
2 - what will the difference be compared to the orbi mesh systems?
my existing orbi system bogs down due to nest cams, Apple TV's, etc - just trying to takes advantage of the wiring
