eddablin
Jul 15, 2022Novice
Nighthawk RAX200. Can't always cast to Google Home Max via Chromecast
Hi all, We have a Chromecast in our office. It isn't always avialablle to cast to and sometimes the Max when this happens it shows as offline in the Google home app. This is despite the Google Ma...
eddablin
Jul 15, 2022Novice
Firmware - v1.0.6.138 (latest)
Gateway is a Virgin Media Hitron CGNV4
Jul 15, 2022Guru - Experienced User
That hiltron is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- eddablinJul 15, 2022Novice
Hi thank you for the help. Ithought the router was in modem only mode. I had to change to a multi-static IP to do this. As we're on static IP it removes the option to enable modem only mode which it call RG function. Is there a way to be sure I am in modem only mode?
