mbonetti
Feb 25, 2020Guide
Nighthawk (RAX200) Connectivity Issues with Some Devices
WiFi connections have been inconsistent with some devices, Amazon Echos mostly, but there are other devices as well. The issues started immediately after setting up the router. The router is usi...
mbonetti
Feb 25, 2020Guide
I found a similar post about RAX80 https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Alexa-not-supported-on-RAX80/td-p/1740058
