MikeBravo
Dec 09, 2023Luminary
Nighthawk RAX200 HT160
I just bought a used RAX200 now that I have a laptop with an Intel AX210 card. I figured I'd learn the new tech and then upgrade later. I can't find a setting on the router to determine if HT160 ...
Dec 09, 2023Guru - Experienced User
If you don't see HT160 under basic, advanced or even under debug.htm, then possible that either the system handles that automatically based on support of the connecting device or its not is not supported by this model router.
I can't find a setting on the router to determine if HT160 is enabled. A search online said it would be under the MU-Mimo setting but it's not there.
Any suggestions?
