MikeBravo
Dec 09, 2023Luminary
Nighthawk RAX200 HT160
I just bought a used RAX200 now that I have a laptop with an Intel AX210 card. I figured I'd learn the new tech and then upgrade later. I can't find a setting on the router to determine if HT160 ...
michaelkenward
Dec 09, 2023Guru - Experienced User
MikeBravo wrote:
I can't find a setting on the router to determine if HT160 is enabled.
Why do you ask? You are having problems connecting something to the RAX200?
You should not have to mess around in the entrails of your wifi settings.
Intel was famously hopeless at providing decent drivers for its wifi chips. If you have problems, that might be something to investigate.
Dec 11, 2023Guru - Experienced User
You shouldn't see HT160. That setting used to enable 160hz channels. On the RAX200, that's automatic when you set your speeds to "up to 4800mbps". the 4800mbps speed requires 160hz wide channels to function.
