pab54
Aug 09, 2020Aspirant
Nighthawk RAX200 won't work with Luma surveillance DVR
I just bought the NightHawk RAX200 that will replace my current Luxel XWR-1750 router. I'm looking for some extra speed. I am having probems connecting my Luma 500-NVR (surveillance camera DVR) to th...
Aug 10, 2020Guru - Experienced User
What modem are you using?
Did you re-run your networking setu pin the luma nvr? Or contacted them to see if anything specific needs to be done during setup?
- pab54Aug 10, 2020Aspirant
Using Arris SB8200 Modem. There is no Network setup in Luma NVR - just a re-boot should do it. Trying to contact SnapAV/Luma for thier thoughts. Just don't understaad why it works great with one router and doesn't work at all with the Nighthawk.
