pab54
Aug 09, 2020Aspirant
Nighthawk RAX200 won't work with Luma surveillance DVR
I just bought the NightHawk RAX200 that will replace my current Luxel XWR-1750 router. I'm looking for some extra speed. I am having probems connecting my Luma 500-NVR (surveillance camera DVR) to th...
Aug 10, 2020Guru - Experienced User
What modem are you using?
Did you re-run your networking setu pin the luma nvr? Or contacted them to see if anything specific needs to be done during setup?
pab54
Aug 10, 2020Aspirant
Using Arris SB8200 Modem. There is no Network setup in Luma NVR - just a re-boot should do it. Trying to contact SnapAV/Luma for thier thoughts. Just don't understaad why it works great with one router and doesn't work at all with the Nighthawk.
- plemansAug 10, 2020Guru - Experienced User
make sure nothing else is plugged into the sb8200. it might have 2 ethernet ports but only 1 device can be plugged into them (for most users/isps)
