mhuusko
Jan 14, 2021Aspirant
Nighthawk rax200
Hi my router report my iPhone and apple watch as havig wired connection!!! What could be the problem?
mhuusko
V1.0.3.106_1.0.58
Using browser interface
Inteno fiber connected modem
Jan 14, 2021Guru - Experienced User
Which ineno fiber modem/gateway? Some have their own integrated routers.
And do you have any extenders or access points on your network?
- mhuuskoJan 14, 2021Aspirant
Inteno XG6746-R1
All my units are connected directly without any extenders to the rax200.
I've had the fiber gateway in more than 5 years, previously conneted to an Asus 88 router.
Have not seen this behavior before.
- plemansJan 14, 2021Guru - Experienced User
Probably because the inteno has its own integrated router. But if everythings work, I wouldn't worry about it.
Think there could be a bug in the firmware since with the Asus all info about connected devices was correct.
Should one just accept that the RAX200 is not working 100%???
