ultravista
Oct 14, 2022Aspirant
Nighthawk RAX29 Router Constantly Dropping WIFI
My Nighthawk RAX29 constantly drops WIFI for some but not all devices. It may stop working for my laptop for example while the XBOX, Vonage, and Google Home and other devices still have internet. ...
ultravista
I've been reading through the forums and it appears my problem is not specific to the device but affecting a lot of other users with varied model numbers. Same exact problem, WIFI drops for some (but not all) devices and wire connections remain unaffected - rebooting the router solves for short period. Rinse and repeat.
Search "WIFI drop" in this forum and you'll see that the problem affects many users independent of the model #.
I am not sure how the devices are connecting 2.4 or 5 ghz. The router is still broadcasting and it shows "connected, no internet".
The RAX29 is connected to a Netgear modem and also an older Motorola surfboard modem. Regardless of which modem, WIFI drops while wired connections are unaffected.
Oct 15, 2022Guru - Experienced User
Yes you will see "wifi drop" as an issue in the forums. Its a support forum where people come with issues. So you find issues here. That applies to any consumer networking forum. Search any of them for "wifi drops" and you'll find a bunch of posts. Its like going to a hospital and searching for sick people. Thats what you'll find. And then you'll think "well, everyone is sick". But its because of where you're at.
Did you try just a factory reset?
And what models are these modems?
- ultravistaOct 20, 2022Aspirant
I have not done a factory reset yet but did disable the AX setting and changed the 2.4 and 5 gHz settings from AUTO to a specific channel.
When looking at the router logs, I noticed an Apple TV that was continually failing to log in. The router considered it a Denial of Service attack. I also unplugged the Apple TV to stop it from attempting to login.
The router has been behaving since making the changes and powering down the Apple TV.
Is it possible the DOS perceived from the router was causing it to sever some WIFI connections? I could not find the lease time of DHCP. If a short time, say 24 hours, perhaps the router would no longer allow additional connections due to the perceived threat? Is this plausible?
- michaelkenwardOct 20, 2022Guru - Experienced User
Maybe the router got bogged down in recording those Denial of Service attacks.
At least, that is one theory.
You could test it by telling your router not to log those events. (That doesn't reduce your protection.) If the wifi issue goes away that would explain it.
