leeforbes
Mar 15, 2024Aspirant
Nighthawk RAX30 disconnects all devices once a day
Nighthawk RAX30 Firmware: v1.0.10.94_3 Exactly once every single day at a random time all devices (wired and wireless) will disconnect from the network for several minutes. When it happens all t...
Mar 21, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
