Paul_0
Jul 02, 2024Aspirant
Nighthawk RAX30 log/email notification bug
I've looked everywhere and can't for the life of me work out where to submit a bug report to Netgear. They don't seem to be interested in allowing customer report bugs. Anyway... I would like to ...
- Jul 09, 2024
Thanks for the tips but I couldn't follow your exact steps as the web page was different and didn't offer the same options. But I got onto "Chat" with an agent any way. All I wanted to do was report a bug as a concerned Customer of their product. Apparently my registered product only had 90 days of technical support and that has long expired. They offered to extend my support (at a cost I presume) so they could "assist" me. They closed the chat before I had a chance to respond within a few minutes. I give up with Netgear's useless support and reporting a problem.
Ever since turning off Email notifications the router has now been rock solid for 9 days. Prior to "testing" email notifications out, it was rock solid for approx 7 months. Definitely a problem in their firmware, but I can't be ar$ed chasing it up any further. My problem is fixed. Just don't use Email notifications on RAX30 routers.
Paul_0
Jul 09, 2024Aspirant
michaelkenward
Jul 10, 2024Guru - Experienced User
Makes sense. Pointless faffing around with something as peripheral as this feature.
One question though, which email service were you using to send messages?
I have found that some work better than others. Some just don't work.
Another finding that sort of confirms your firmware suspicion is that I have tried email logs on a handful of devices. These routers don't all behave in the same way. Some are fine with GMail, others bomb out.
