tjlyons52
May 11, 2025Follower
Nighthawk Rax30 not showing correct speed after fiber installed
Old comcast name/login on Nighthawk rax30 does not allow full speed of new ATT fiber speed of 500. Instead, speed test shows 87. ATT technician connected my NH to the ATT Gateway with an ethernet cab...
May 12, 2025Guru - Experienced User
That you're in a double nat with both devices in router mode.
What actual att gateway is it? Some are pretty decent.
Are you wanting to use both the ATT gateway and the Netgear? IF so, just put the netgear in access point mode.
