TKay74
Apr 16, 2026Aspirant
Nighthawk RAX30
Hello!
I can't figure out how to change my router name & password. All support has expired so I'm hoping someone here can help guide me. Thanks in advance for any help.
Perhaps start with the User Manual:
https://www.downloads.netgear.com/files/GDC/RAX30/RAX30_UM_EN.pdf
page 16
- TKay74Aspirant
Thanks!
If you can't log into the routers web page, may need to factory reset it and then setup form scratch:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Can then use the routers web page to make changes where needed.
- TKay74Aspirant
Thank you!
