Moline's avatar
Moline
Guide
Dec 08, 2019
Nighthawk RAX35 conncting to hotspot
Hello, I got a great deal on the Nighthawk RAX35. I bought it and now I am trying to figure out if I can use my Sprint mobile hotspot device to supply internet thru the RAX35 so my corded pc's can u...
  • Moline's avatar
    Moline
    Dec 19, 2019
    Found my own solution after buying a few other wireless routers/repeater. The one I found that is working well is a AMPEDWIRELESS High Power AC2200 WI-FI Range Extender (RE2200T), easy setup, found my hotspot device as soon as it was turned on. set my passwords for each frequency 2.4ghz, 5ghz and unit did its reset and now my wired pc's are connected to my hotspot.
