balickma
Jul 22, 2020Follower
Nighthawk RAX35 dropping connection frequently since firmware update
Hello, I have been using this router for a while now with generally positive results. I recently updated the firmware to version V1.0.3.80_1.0.1 and since I have been getting frequent drop offs ...
Jul 22, 2020Guru - Experienced User
Rolling back firmware is fairly simple. I'd recommend doing it over a hardwired connection.
Basically you download the old firmware from the support site under +view previous versions. Extract it.
And then follow the manual firmware update process from the manual but use the older firmware instead of the new version.
it can be found here: https://www.netgear.com/support/product/rax35
you can try factory resetting and reinstalling first though. The RAX devices have responded favorably to that option as well.
- dubblebJul 22, 2020Aspirant
I have been having the same exact issue and it has gotten worse today with the same code. Any idea of what version of code was stable previously. Sounds like I need to rollback and disable auto udpates if this works.
- er65nsunnyAug 04, 2020Guide
I was having the same problem. Could not figure it out. Then I noticed my phone was only showing NETGEAR24-5G for the wifi channel no NETGEAR24. I logged into the router aqnd checked the wireless names and both the 2.4G and 5G were both labeled as NETGEAR24. I managed to get the 5G to change to NETGEAR24-5G and it seems to work now. Hope it stays this way.
