balickma
Jul 22, 2020Follower
Nighthawk RAX35 dropping connection frequently since firmware update
Hello, I have been using this router for a while now with generally positive results. I recently updated the firmware to version V1.0.3.80_1.0.1 and since I have been getting frequent drop offs ...
dubbleb
Jul 22, 2020Aspirant
I have been having the same exact issue and it has gotten worse today with the same code. Any idea of what version of code was stable previously. Sounds like I need to rollback and disable auto udpates if this works.
er65nsunny
Aug 04, 2020Guide
I was having the same problem. Could not figure it out. Then I noticed my phone was only showing NETGEAR24-5G for the wifi channel no NETGEAR24. I logged into the router aqnd checked the wireless names and both the 2.4G and 5G were both labeled as NETGEAR24. I managed to get the 5G to change to NETGEAR24-5G and it seems to work now. Hope it stays this way.
