EagleGrampa
May 04, 2020Tutor
Nighthawk RAX35 drops nternet connection
My wifi router is Nighthawk AX4: RAX35 AX3000 (from the device label) HW Version R1.0.5 FW Version V1.0.3.62_1.0.1 It seems that overnight, nearly every night, my router loses internet connecti...
dustjim
Jun 27, 2020Aspirant
I am having the same issue, did your issue get fixed?
EagleGrampa
Jun 28, 2020Tutor
Hello. I reset the device to factory defaults and then made everything the way it was before the factory reset. I haven't had an issue since I did that. Additionally, there has been 1 firmware update since then and I also implemented that new firmware version.
Good Luck
- kvik369Jul 15, 2020Guide
Is your router still working fine ?
- EagleGrampaJul 15, 2020Tutor
I would say yes, it is.
ok thanks
