Retired_Member
Feb 25, 2020Nighthawk RAX35 Link state slows from wifi side to lan side of router
2.4 wifi gigabit side slows when connected to Lan side that uses 1-gigabit link connection. I use a server that connects on the LAN side gigabit of the router and when i Access it from the wifi side...
Retired_Member
Feb 26, 2020Just tried the router set to (AC) mode and from wifi side it drops way down of speed link instead of 2.4Gbps to around 702 Mbps linked state speed with wifi connecting to server on Lan side of router.
LAN side of router should not pull down the wifi link state speeds.
Now yes there is some up and down with wifi signal path but this new intel AX200 is solid as a rock 2.4Gbps Linked state speeds when not
connecting to the lan side from the wifi side to a lan server.
Auto-negotiation is definetly messesd up some where.
Christian_R
Feb 28, 2020NETGEAR Employee Retired
Hello Jeff44,
Welcome to the community! Our engineering team is currently investigating reports of WiFi performance on the RAX35. Have you got a chance to get in contact with our Support Team regarding your issues?
Thanks,
Christian
