NMLiz
Feb 13, 2022Guide
Nighthawk RAX38v2 dropping Internet since firmware update
Tonight I noticed on my iOS Nighthawk app that there was new firmware for the RAX38v2, so I told it to update. It took a short time, and then the app could no longer find the router...right, restarti...
Feb 14, 2022Guru - Experienced User
What modem/gateway are you connected to?
Waht I'd try doing? Anytime there's an issue after a firmware upgrade, a reasonable first step is to factory reset. Sometimes old settings can cause issues. If that doesn't help, try re-installing the firmware to the router over a hardwired connection. When we see corrupt firmware issues, it tends to be when people updated over wifi or using the app.
- NMLizFeb 15, 2022Guide
OK, I will try a reset, which makes sense.
Our modem is a Windstream Actiontec 3200, which is in bridge mode. We are in a rural area, so we are lucky if we get 10 Mb. I am wondering if Armor is simply adding more drag on our speed.
- plemansFeb 16, 2022Guru - Experienced User
Let me know if it works or not.
