JuanDollar
Jul 23, 2020Tutor
Nighthawk RAX40 Connection Issues
I have been experiencing strange issues connecting to my Nighthawk router. I have a Virgin Media Super Hub 3 which is in Modem Mode and the RAX40 connected to it. The issues I have are threefold and ...
- Aug 04, 2020
Resolved: These issues were resolved by re-flashing the firmware and/or disabling the AX functionality. I did both at the same time so dont know if it was one or the other for certain. Its now been stable for over a week.
Jul 23, 2020Guru - Experienced User
Not all device makers code "modem only" mode or passthrough mode properly. or they make it difficult to get functioning properly.
It sucks when this happens.
What I'd try doing?
Put the super hub back in router mode.
You can then either put the RAX's ip address into the super hubs dmz or you can place the RAX in access point mode. this prevents a double nat.
If you'd like you can leave the super hub's wifi running but you'd want to make sure its on different channels than the RAX. or you can disable wifi.
- JuanDollarJul 24, 2020Tutor
Thanks for the reply! I intially had it set up similar to that and had all the same problems so went right back to basics to keep it simple, although I dont believe I put the router IP into the DMZ so will try that and let you know how it goes.
- JuanDollarAug 04, 2020Tutor
