JuanDollar
Jul 23, 2020Tutor
Nighthawk RAX40 Connection Issues
I have been experiencing strange issues connecting to my Nighthawk router. I have a Virgin Media Super Hub 3 which is in Modem Mode and the RAX40 connected to it. The issues I have are threefold and ...
- Aug 04, 2020
Resolved: These issues were resolved by re-flashing the firmware and/or disabling the AX functionality. I did both at the same time so dont know if it was one or the other for certain. Its now been stable for over a week.
JuanDollar
Jul 24, 2020Tutor
Thanks for the reply! I intially had it set up similar to that and had all the same problems so went right back to basics to keep it simple, although I dont believe I put the router IP into the DMZ so will try that and let you know how it goes.
JuanDollar
Aug 04, 2020Tutor
